iPhone 6 liquid damage no touch
wgaca
Originally J2401 was liquid damaged and had to be replaced. After replacement, there was still no touch.
The touch IC was also corroded around C2410 so I ended up replacing U2402 as reflowing didn't help either.
After that, there is still no touch. There was more damage but since the phone is turning on I ignored the rest.
It doesn't look like there are broken lines between the connector and the touch IC. Not that measuring them will be easy.
What should I check. What is required for touch to work?
