macbook a1708 820-00840
ipetro
HI. I need help with this board! 5v/0a stable. Replacing the u7000 did not change the situation. Before I move on to replacing the SD3215, maybe there are some tips on what to pay attention
ipetro
PPBUS_G3H=0.002v/diod=0.402
all indicators on the coils are normal and there are no short circuits
You should get C7050 voltage even with 5V input.
Post U7000 basic voltages: P_IN, AUX_DET, SMC_RST_IN, VDDA/P, EN_VR1, SMC_RST*, AUX_OK, A/BMON.
Keep F7000 removed.
BTW, put some logic on your job; avoids wasting time.
"C7050=0.005V(pin2)"
I can't still believe that you've checked GND to GND voltage!
ipetro
to exclude the u7000, I removed it from the fully working board and placed it on this board, but the result is the same.
U7000
1=0.002V
2=5.07V
3=0.002V
4=0.007V
5=4.76V
6=0.002V
7=0V
8=0.002V
9=0.003V
10=5.07V
11=4.81V
12=0V
13=0V
14=0.003V
15=4.75V
16=0V
17=5.07V
18=1.26V
19=0.004
20=5.07V
21=0V
24=0V
25=1.128V
26=4.76V
27=5.07V
28=3.4V
29=0V
30=3.4V
31=0.002V
32=0V
33=3.38V
34=5.07V
35=2.7-3.4V unstable
36=0.002V
37=0V
38=3.4V
39=3.4V
40=2.7-3.4V unstable
Please, use schematic notations!
I have 10-20 schematics opened in Acrobat Reader, but I don't want to open boardview for each one.
You are the one working on the board and need the boardview.
The schematic allows to interpret the measurments, not the boardview!
ipetro
Let's get back to the board problem!
P_IN, =apparently you mean PPVIN_G3H=4.76V
AUX_DET, =apparently you mean TBA_AUX_DET=1.26V
SMC_RST_IN =0V
VDDA/P, =apparently you mean TBA_VDDA=5.07V and TBA_VDDP=5.07V
EN_VR1, =apparently you mean BANJO_ENVR1=0.031V
SMC_RST*, =apparently you mean SMC_RST_IN=0V
AUX_OK, =apparently you mean SMC_AUX_OK=3.4V
A/BMON.=apparently you mean CHGR_AMON=0.004V and CHRG_BMON=0.003V
You do NOT have 00840 schematic.
Is just renamed 00875 schematic; the only one available.
"apparently" no, is just what I meant.
Take less time using U7000 internal names than external ones; however easy to follow on the schematic.
Check diode mode to ground at C6990 and L6995.
3V3_G3H must come first, before PPBUS_G3H.
For some reason, U7000 doesn't enable it.
"SMC_RST*, =apparently you mean SMC_RST_IN=0V"
Look better at schematic.
Some U7000, or U6990 adjacent component may be bad; or trace.
What is C6990 voltage?
Why do you insist so much with boardview?
Don't you want to see U7000's corresponding signals directly in schematic (all at same time)???
And yes SMC_RST_L is the expected signal for SMC_RST*; not visible on boardview, of course.
"Some U7000, or U6990 adjacent component may be bad; or trace.
What is C6990 voltage?"
ipetro
I apologize for my inexperience, but I’ve been with you for three months and don’t have the knowledge that is obvious to you!
If U7000 is good for sure and properly soldered, it should enable 3V3_G3H power supply.
Check/replace C7071 and R7008/76/77.
Also check/replace all R/C/Q7030/40.
ipetro
I'm changing t2 chips so something like u7000 or cd 3215 is too easy! there, no less, to exclude the u7000, I removed it from a fully working machine and checked in diode mode all the indicators around it were normal; the u7000 removed from this board works perfectly on the donor board. I turn off u7000
