Macbook A2289 820-01987 won't turn on
ipetro
A cyclic reboot occurs on one of the ports. on the second hangs 5 V and 0.257-0.300 A. What to check ?
PPBUS_G3H=12.3v
U3100
PP3V3_UPC_XA_LDO=3.299v
PP1V5_UPC_XA_LDO_CORE=1.58v
PPDCIN_G3H=5v
U3200
PP3V3_UPC_XB_LDO=3.290v
PP1V5_UPC_XB_LDO_CORE=1.58v
PP3V3_G3H_RTC=3.3v
PPDCIN_G3H=5v
Compare diode mode readings around CD3217 chips.
Pay atention to CC1/2 lines.
ipetro
Thank you for your greeting, I hope our cooperation will be fruitful :).
U3100:
USBC_XA_CC1=0.553
USBC_XA_CC2=0.552
U3200:
USBC_XB_CC1=0.553
USBC_XB_CC2=0.553
I especially mentioned CC1/2; but I expected you to check more points around CD3217 chips.
You have different behavior on the ports, so possibly one chip is bad; or some adjacent component.
If both chips give similar readings, then you need to change them.
ipetro
UPC_XB_SWD_CLK=0.013
UPC_XA_SWD_CLK=0.538
SPARE_UPC_XA_USB3_RP=0.682
SPARE_UPC_XB_USB3_RP=0.011
USBC_XB_SBU2=0.012
USBC_XA_SBU2=0.700
Thanks to your parting words, I understand that the U3200 chip (CD3217) needs to be replaced?
ipetro
After replacing the SD3217, the MacBook runs on battery power but the USB-C ports do not work. If you disconnect the battery, one port is cyclically overloaded. I'll attach a video of the ports
ipetro
The fact is that the CD3217 chips were transferred from a fully working donor board and I moved the top chip to the top and the bottom chip to the bottom. that is, I changed them one by one and could not confuse them because I knew that they could not be confused. The U7000 chip was also transferred from the donor board, but for some reason it still didn’t work and the ports behave differently. When connecting the J6951 cable from the battery, the second port does not work at all. Tell me what to do next?
ipetro
I also noticed that the voltage when the voltage is applied is PP3V3_G3H = 3.3V and then drops to 3.24V
ipetro
After replacing the u2890 everything worked as it should. All USB ports work and the MacBook is charging. I went to Internet recovery and erased the disk, but I can’t install the system back. The installation begins and after a while it suddenly turns off. Through DFU, the installation of the system also reaches 50% and it turns off and does not allow the system to install.
Try to install anothger macOS version.
Start with Option + Command + R; will offer you the latest macOS compatible with your machine.
Command + R will allow you to install the last macOS version used on it.
Shift + Option + Command + R will reinstall original macOS which came with the machine.
ipetro
There is a problem with the touchbar; it flashes green and turns off, this prevented me from installing the system. After turning off the touchbar, the system was installed and everything works except the touchbar! Is this a problem with the touch bar or could there be some other problem?
ipetro
I installed the a2338 in the case and the touchbar works on it! The problem is in the touchbar!
ipetro
there is an unknown problem! Sometimes when you open the display lid, the keyboard backlight turns on but the display does not turn on! Also, every time you reboot, a message appears that the MacBook shut down incorrectly. Resetting SMC and PRAM did not help.
