Macbook A2337 820-02016 Camera Issue
Instafixx
Macbook A2337 Camera Issue
Device was stuck in Round Logo with a slash inside it (Recovery or No Software).
Water Damage as the small audio board. Cleaned it. Turns on now.
Had to replace the trackpad flex cable as well.
Everything fine now except "No Camera Connected".
PP5V_MAIN_ALSCAM_F is 5V
I2C_CAM_SDA/SCL lines surrounding UD120/140 also ok.
Getting 0.5V at LP607 and LP609
Replaced the TCON board as well.
Tried a different LCD assembly too.
Then is not mounted; schematic also mentions something about that.
Check continuity for camera lines from MLB to TCON.
You may have problems with JP600, or its cable.
Instafixx
Since i have tried a different TCON board and also a different lcd assembly. JP600 should be the suspect here.
Diode reading there is normal. What else to check?
Instafixx
i think customer must have tried to do some software or something in that original condition that led to camera issue.
i did a DFU Revive and now camera is working.
Instafixx
Hello,
I have. similar case for LP670 was burned along with UP700.
Replaced all.
Replaced TCON Board.
I get 5V at LP670
LP607/9 is 0.5V
LP680-85 also 0.5V.
UD120 and UD140 also okay .
Still no camera connected issue.
Instafixx
Yes.
Tested another board on this chasis as well.
LCD and Camera are okay.
Can it be faulty UP700 although voltages are present.
