Macbook Air 802-00165-A Good backlight fuse, bad wled?
brooke.j
Hi, I have been looking for a schematic for 802-00165-A and I'm not happy with the last place I bought from so can you suggest somewhere or is that not permitted here? Here is what I know: Minor liquid damage board looks great. -Powers on with no backlight but works with external monitor. -The backlight fuse is good (tested and open) but I don't have a schematic to test the wled. - Does anyone know the pin voltages?
Thanks
brooke.j
Ok now I have the board view and schematic. So I think I'm on the right path. I have another board here (same one) for parts and I'm hoping I can take the WLED driver off of it, if that is what the issue is. Any suggestions or comments are greatly appreciated.
brooke.j
Perfect, New here so didn't know where to look. Of course there is a sticky on the subject. I'll start probing asap.
brooke.j
Ok I just want to say that if you tell me once I won't make the same mistake again. I measured the fuse by putting red probe on power coming into fuse and black on ground and blew the fuse. Probably a noob mistake. I'll replace the fuse and move on. I have a basic understanding of measuring voltage and I"m here to learn. I'm probably stupid because for the life of me I can't google anything that says to test differently for voltage. Also great sticky on voltages but where do I test for the 39v-49v, at the lvds connector right? Total dumbass I know but thx for the help.
brooke.j
Ok so I blew a perfectly good fuse, no prob I've replaced those before. Without changing the fuse I notice that Pin 1 of the Backlight fuse Reads 8v. Should I be getting12.6v?
brooke.j
I'm an idiot. For some reason I had my probes connected to my multimeter wrong. Gotta get some fluke full proof gear. OK lesson learned.
brooke.j
Hi again, should I be testing the PP3V3 on the LCD connector to post voltages outlined in Louis' sticky post? Or or should I be testing PPHV_S0SW_LCDBKLT? Where is the best place to test the backlight voltage?
brooke.j
Hi guys. Can you tell me what component I need to test so that I can give you the voltage readings you asked for? I'm a little lost but not dumb so that's why I joined this forum in hopes of filling in the missing pieces. I'm really grateful to have any help you can spare. Thank you
brooke.j
HOLY SHIT!! Thank you so much for that!! You totally made it make sense now. I was testing at the lcd connector on pin 3 (no voltage btw) and doing most of what is described but I just needed someone to put it all into context. I'm a very visual learner and the way you explained it made a great picture in my head now that I have been getting familiar with the schematics and .brd....I don't feel like a tool anymore. WOW Thank you thank you thank you. And please tell me to get my head out of my ass if I ask a stupid question and correct me or tell me I have my head up my ass because of X,Y, and Z. One last thing. If I do need to replace the LP8550 is should I be getting 926-LP8550TLE/NOPB or 926-LP8550TLX/NOPB
from mouser.com? OH I SEE THAT YOU CAN ORDER MIN 1 OR MINIMUM 3,000 IN RESPECT TO THE PART NUMBER (is that the only difference?)
brooke.j
Hi, again. I've taken this two weeks to really study and make sure I am able to diagnose in the correct way that will help the forum. (mostly you and Louis so far) to help me without talking to a total moron. Check out my new posts. I hope I've narrowed it down to the Q7707. Thx
brooke.j
OK I've been studying and I think I'm ready for some advice that won't be wasted on a total n00b!
Here is what I did.
-I checked the SMC_LID = 3.42v
-I changed the WLED DRIVER (JUST TO SEE IF I COULD DO IT) I did it twice and didn't muck up any pads. I used this part from mouser.com:
926-LP8550TLE/NOPB
MFG Part No:LP8550TLE/NOPB
LP8550TLE/NOPB
TI LED Lighting Drivers
US HTS:8542390000 ECCN:EAR99 COO:MY
The part went on great and I didn't burn it and I also saw it float around on top to make sure all balls were liquid.
I was getting 3.4 on the third pin of LCD connector on and off. Which is weird. Then I decided to make sure that the LVDS connector was soldered well and had no corrosion. After that I plugged in the display and it blew the backlight fuse.
-Replaced backlight fuse. Now no 3.4v on LCD connector.
Here are my readings now.
R7788 PIN 1 = 7.88V
PIN 2 = 7.66V
R7789 PIN 1 = 7.66V
PIN 2 = 7.56V
Q7707 PIN 3 = 7.58v ( should it be lower? )
PIN 2 (BKLT_PLT_RSTL) = 3.34v
PIN 5 (EDP_BKLT_EN) was giving me 3.4v and now is 0v after unplugging LCD connector.
So it looks like the voltage is getting lower from Q7707 but is it now low enough? I know that there could be a short somewhere but if you think replacing Q7707 might be the right direction?
Thank you again for all your help. I have put in mad hours to learn more and not have your time wasted.
aprendiz
Moderator
You have a bad display and/or cable and now maybe a bad connector again (hope not), EDP_BKLT_EN only will be present if display is detected, when you get EDP_BKLT_EN and BKLT_PLT_RST_L you will have the right voltage at gate of Q7706...
Try with a known good display assembly..
