macbook air m4 13" A3240 821-05409 5v
yair37
another air 5v case..this time is m4 13" water damage all the board look very clean, LDO ALL OK.
PPBUS_AON 12.2 STABLE
All the secondery voltage pulsing every few secound. no short no board.
CHGR_SYS_5V also pulsing.
CHGR_CSI_FILT_P 5v stable.
yair37
see it here:
The 2025 MacBook Air M4 (13-inch, Model A3240) logic board generally uses part number 821-05409-02. These M4 models (13" A3240, 15" A3241) feature soldered memory and SSDs, and they require a paired Touch ID sensor with the replacement board.
MacBook Air M4 (2025) Board Details:
  • 13-inch (A3240): Board Number 821-05409-02.
But you right...the board is 820-03597 (Why don't they engrave on the board anymore).
Im using m3 board its very similar..so..
Ask the customer, where the liquid was spilled.
Test the board alone, disconnecting anything else apart the charger.
Also disconnected daughter board (keyboard interface)?
Should be good to test with known good battery.
