myiannakou
With battery connected the charger light will after 30 seconds or so turn off. MacBook will still stay on and run but battery no longer charging.
I then have to remove the charger from the mains and count to 20/30 seconds before the charger will work again.
If I plug the charger back in the same thing will happen.
With battery connected PPBUS is 11.33v (which is wrong) should be 12.56
If I disconnect battery PPBUS back to normal.
The board must of has some work done on it in the past as it's been run through an ultrasonic ( I can tell)
Can't see any signs of corrosion although the dc-in port was burnt out when client dropped it off.
Have tried SMC/PRAM resets. Have tried a new battery. Have not tried an SMC reflow yet
