MacBook Pro 16" - 820-01700-A - 5V / 0.02A dead after connecting USB-C docking station
quasimodo
Hey!
History for the board:
water damaged / on top of the case
replaced U3500 + Q3501 - board was working fine
-> usb-c docking station connected on the side of the water damage -> dead -> 5V / 0.02A
ppbus_g3h is 0V
should i just replace the CD3217 or where to start to troubleshoot?
Diode mode to ground on PPBUS_G3H?
Also check diode mode around CD3217 chips.
Any voltage at R7020?
Please, STOP to diagnose by beeps!!!
Check resistance in ohm scale.
BTW, multimeters beep untill 0.050-0.070, depending by model.
CPU core voltage is on L7211/21/31.
Also check on L7410/20 (iGPU core).
Compare ohm readings with the value on PPBUS_G3H.
If no other coils give you same 0.3 ohm to ground, then is safe to inject voltage into PPBUS_G3H.
Start with 1V and increase slowly, if needed.
Set the amp limit on PSU to max.
First be sure you've checked all the coils; don't forget L9080/580.
