cralx2k
Hi all.
I have a macbook pro (2009/2010) that I haven't used for a long time. Only the charger green light turns on. I did all resets and still the same. I checked Louis Youtube video and the PP1V05_S5_MCP was measuring 3mV. I replaced C7771 and the rail back to normal 1.1V. I installed only the fan to check if it would run and nothing. I installed back the board and battery is disconnected. Using the power bottom, the fans still do not run. The measurements I did so far are attached.
I have some newbie questions:
- How to power on/off the board without the power bottom?
- In the image attached the table shows SMC_PM_G2_ENABLE will be 0V with out Battery. So the P3V3S5_EN also will be 0v and U7201 will be disable and PP3V3_S5 should be 0v like I measure even though is S5 rail?
- This voltage for the original charger (16.69V) is normal?
- Where I buy original charger and battery?
Any feedback is appreciated.
Ps: the board is in excellent condition.
Ps1: Louis you're the man. Love your Youtube Channel... Big Fan for long time.
Thanks All
Thanks All
PP18V5_DCIN_CONN | 16.69V |
PPBUS_G3H | 8.4V |
PP3V42_G3H | 3.4V |
PP1V05_S5_MCP | 1.1V |
PP3V3_S5 | 0V 630ohms |
PP3V3_S5_REG | 0v |
PP5V_S3_REG | 0v |
PPVIN_S5_P5VP3V3 | 8.4V |
P3V3S5_EN | ??? |
