MBA 2013 - 820-00164 - not charging - orange light
uli
Hello,
my daughter's MB ceased to charge after she twisted the cable from a charger that it got shorted which fired a house breaker. The computer worked until the battery went dead.
  • The orange light is on, but it draws only around 65 mA.
  • The computer cannot be started with or without a battery connected on a adapter, but I suppose it would start if the battery was charged. I don't have a spare one.
  • When I do reset (Ctrl+Opt+Shift+Power) the light turns green for a few seconds and then again gets back to orange.
What should I measure? Can I create some external circuit to charge a battery to check the function?
Thank you
Uli
uli
PP3V3_S5 is dead zero. Not beeping to the ground, only short capacity beep.
PP3V3_SUS is, if I understand the boardview correctly, available from the other side. I will be able to disassemble the computer in few days.
Thanks
Uli
Post U7501's basic voltages: pins 23, 22, 12, 13, 29, 21.
Just in case, check diode mode to ground on all big coils.
BTW, write directly into bottom reply box, instead of clicking Reply button.
Please, maintain forum aesthetic...
uli
Hello,
PP3V3_SUS has nothig, 0.003 mV respectively.
U7501:
23 3.090 V
22 3.085 V
12 3.420 V
13 1.997 V
29 3.037 V
21 3.420 V
Coils to ground both ends (value after settling down):
L7320 14ohms beep
L7310 14ohms beep
L7430 ol short capacity beep
L7630 346ohms short capacity beep
L7130 ol short capacity beep
L3095 ol
L7701 ol
L7560 ol short capacity beep
L7520 ol
Just to be sure - I am feeding it 14.85V as written on the apple power supply. I have just the mainboard connected with magsafe board over J9500 and J7000. It is my first MacBook repair.
Thanks
Uli
Impossible to get OL in diode on any coil.
Just check again with RED probe connected at GROUND.
"L7310 14ohms beep"
14 ohm is correct reading for CPU core.
BTW, no need to check on both pins of a coil to ground.
"23 3.090 V"
Are you sure PPBUS_G3H is only 3V???
uli
Appologies for my mistake. So the diode to the ground with red on the ground. I have used the beeper.
L7320 0.0233V
L7310 0.0233V
L7430 0.238V
L7630 0.177V
L7130 0.153V
L3095 0.533V
L7701 0.431V
L7560 0.370V
L7520 0.440V
And the PPBUS_G3H is realy 3.09V.
Thank you
uli
The battery is removed and also the F7140 is still removed.
U7100:
1 0.0242V
2 13.3V
3 3.87V
9 0.033V
12 3.416V
13 3.383V
14 3.383V
15 0.0705V
17 3.215-3.268V oscilating
19 4.988V
20 4.742V
27 0.745-0.750V fluctuating
Also, the current drawn is little higher then in the beggining, if it makes any difference, now 74mA.
uli
R7180 100.4 kOhm
R7181 61.4 kOhm
R7185 471.1 kOhm
R7186 331.7 kOhm
Resitors look good according to schematics.
I made also D-S diode test on 7/8/9/10 -> 1/2 and 7/8/9/10 -> 4/5 on Q7180 with result around 0,52V. Opposite OL.
All other D-S-G combinations were OL with beeper.
uli
Q7180:
1/2 14.755V
3 5.998V
4/5 17.235V
6 14.108V
7-10 14.773V
I have also tried to measure current sensing circuits and R7150/1/2 look good. R7120 looks also good, but R7121/2 have strange readings. Like 5.5kOhm and 324 kOhm. Definitely not 10 Ohm.
Also, the fuse is still removed.
Replace R7121/22 and check their traces to R7120.
Also check diode mode to ground at pins 27 & 28 of U7100.
If all good, check again C7140 voltage.
uli
I will have to get those resitstors what will take few days.
Should I return the fuse already?
You can resolder F7140.
R7121/2 can be replaced with 4.7-22 ohm resistors; even direct bypass will work.
Be sure first no short on pins 17 & 18 of U7140 to ground; C7121/2 suspects in such case.
uli
I could finally continue the work on the board. I have removed those two resistors. I have found no U7140 (in the board view nor the schematic) ... you probably mean U7100.
I also tried to beep C7121/2 and in case C7121 I got short. Unfortunately, the short is still there when the cap is removed. I think that pin 28 on U7100 is shorted to the ground. Which is unlucky because I do not have a donner board.
uli
Yes. When the U7100 is removed, the short is gone. Is there a verified worldwide source from which it can be bought?
