Missing PP3V3_S5 on A2141 board 820-01700
I am fixing a mac book pro model A2141, the motherboard model is
820-01700
At first when I connect the USB-C charger the voltage was only 5v, then
I check the pin VIN_3V3 C20 on U3100 line
PP3V3_G3H_RTC_X = 0 volts
PP3V3_G3H_RTC_X is provide by U6940
Checked EN E4 line on U6940
CHGR_EN_MVR_R= 0.5 v, too low to work ok
Check CHGR_EN_MVR for shorts but its ok
CHGR_EN_MVR_R coming from U7000
Check all voltages in U7000, everything its OK but CHGR_EN_MVR its low voltage
Then I replaced U7000
U7000 replaced and now I have 20.15 v and 0.032A to 0.036 A on the input but MacBook don’t start
PP5V_S4_X_USBC = 0v
UPC_X_5V_EN_R = 0V
PM_RSMRST_L = 0V
UPC_X_5V_EN = 0V
PP1V8_SLPS2R = 1.8V
PP3V3_S5 = 0V
PP3V3_G3H_SOCPMU = 3.36v
PP1V8_SLPS2R_PMUVDDGPIO = 1.8v
PMU_VDD_HI = 12.62v
PVCCPRIMCORE_SW0 = 0v
PVCCPRIMCORE_SW1 = 0v
PVCCPRIMCORE_FB = 0V
PPVCCPRIM_FETIN = 0V
Check all these lines for shorts but they are ok, specially the line PP3V3_S5 = 0V
Do I need to replace U7800? This U7800 can be purchased new or I need to get it from a donor MacBook? Thank you very much for your support.
First of all ¡bienvenido al foro!
As a basic step for T2 machines, try to put in DFU mode.
If can't do it, check if all AWAKE and SLPS2R voltages are present.
If can see it in DFU but can't complete the process, then check if all SSD voltages are present.
Ok, i tried to put it in DFU mode but 2 seconds later comes back to the screen that says connect devices, then 8 seconds later it tries to connect but again comes back to the same screen and repeat the same
AWAKE VOLTAGES
PPVDDCPU_AWAKE = 0.75V
PVDDCPUAWAKE_SW0 = 0.75V
PVDDCPUAWAKE_SW1 = 0.75V
PVDDCPUAWAKE_SW2 = 0.75V
PVDDCPUAWAKE_SW3 = 0.75V
PVDDCPUAWAKE_FB = 0.75V
PVDDCPUSRAMAWAKE_SW0 = 0.8V
PPVDDCPUSRAM_AWAKE = 0.8V
PVDDCPUSRAMAWAKE_FB = 0.8V
PP3V3_AWAKE = 3.37V
PP1V2_AWAKE = 1.19V
PP1V2_AWAKE_SOC_PLLCPU_F = 1.19V
PP1V2_AWAKE_SOC_PCIEREFBUF_F = 1.19V
PP1V2_AWAKE_SOC_PCIEPLL_F = 1.19V
PP1V2_AWAKE_SOC_PLLSOC_F = 1.19V
PP1V2_AWAKE = 1.19V
PP1V8_AWAKE = 1.8V
PP1V8_AWAKE_SOC_FMON_RC= 1.8V
PP1V8_AWAKE_SOC_TSADC_RC= 1.8V
SLPS2R voltages
PP0V8_SLPS2R= 0.8V
PP1V1_SLPS2R= 1.1V
PP1V8_SLPS2R= 1.8V
PP1V8_SLPS2R_SOC_LPADC_RC= 1.8V
PP1V8_SLPS2R_SOC_LPOSC_RC= 1.8V
PP1V25_SLPS2R_SMC_AVREF= 1.25V
PP1V8_SLPS2R_PMUVDDGPIO= 1.8V
PP1V25_SLPS2R_SMC_AVREF=1.25V
AWAKE and SLPS2R voltages look good; if steady, of course.
Don't worry, you will understand in time what you need to measure and what not.
Is normal to waste some time at the beginning, with irrelevant checkings.
Did you exactly follow the steps in DFU tutorial linked on the forum?
Be aware at the connection cable quality.
question : PP5V_S4_X_USBC= 0v, its provided by L3500=0v and coming from U3500, UPC_X_5V_EN_R enable U3500 and is 0 v, this is normal?
"Will not appear, until an USB device is detected, on the corresponding port."
Do I need to write in capital letters?
That voltage (as LB700 too) is for power up external USB device, WHEN is detected!!!
Each coil serves for one pair of USB-C ports.
It is controlled by T2.
May not appear, if T2 is not able to control power on sequence.
This can be a result of T2 firmware corruption.
Is the reason of DFU attempt.
