pm_slp_s4_L missing 820-00165
shanenin
I have a board with no obvious signs of water damage. Part of me thinks it may have been cleaned at another shop. I am not getting my s4 rails to come on. Here is what I know
I am using a genuine 85 watt charger
I have these rails present
8.6 ppbus
3.42 pp3v42
3.3 pp3v3_s5
5.0 pp5v_s5
I have some but not all of the following signals which I have been told are important for s4 states
0.0 PM_SYSRST_L
0.0 PM_PCH_PWROK
3.3 PM_RSMRST_L
3.4 PM_PWRBTN_L
3.4 SMC_ADAPTER_EN
3.3 PM_BATLOW_L
I have tested u1900 with an oscilloscope and do have a clock signal
u1950 looks perfect and I have power to it, but no output
3.42v on pin 8
I do NOT have any voltage at pm_pch_pwrok
I have no corrosion around the bios chip and the test points look good
the issue seems to be at u1950, but don't understand what enables it
Trigger SMC_ONOFF_L signal and check if PM_PWRBTN_L drops to 0V at same moment.
It should come back to 3V when SMC_ONOFF_L is released.
If it reacts, then check if PM_SLP_S4_L pulses at least in that moment.
Be aware of wrong assumptions; these are S0 signals...
"I have some but not all of the following signals which I have been told are important for s4 states
0.0 PM_SYSRST_L
0.0 PM_PCH_PWRO"
shanenin
Thanks 2informaticos!
how would I trigger SMC_onoff_L?
So I understand the bigger picture, Is u1950 needed for s4 power state? I thought, maybe incorrectly, it was, but if its main signal outputs are for an s0 state that does not seem to be the case.
"how would I trigger SMC_onoff_L?"
Solder a wire at SMC_ONOFF_L line and touch the ground with it; R5115/16 pads can be used.
U1950 has ALL_SYS_PWRGD as main input; which appears in S0 state, just before the VCORE.
shanenin
when I trigger smc_onoff_L it does cut the power to pm_pwrbtl_L and it also causes a pulse on pm_slp_s4_L when looking on the oscilloscope. What does this mean? Just trying to understand
Do not tied SMC_ONOFF_L to ground; just touch the ground for an instance, like pressing power button...
shanenin
I only attached a wire to smc_onoff_l then tapped the other side of the wire to ground when I wanted to trigger it. Something else is keeping the smc off :-{
SMC_RESET_L is OK, as you have correct PPBUS_G3H and Magsafe light even.
Unelss the actual situation is different; please confirm.
"now I noticed the green light is off and my ppbus just dropped to 8.1v"
PM_PWRBTN_L should go back to high level, when SMC_ONOFF_L is released.
BTW, do NOT quote an entire post from few cm above; is not aesthetic...
shanenin
1. something changed, my ppbus is now just 8.1 and I have no light
2. I no longer have PM_PWRBTN_L voltage (probably related to the smc not turning on)
Recheck all the points you tocuhed before PPBUS_G3H went down.
Do you get 3V at SMC_RESET_L?
If not, solve that...
