[SOLVED]820-2850 with grafik problems
Dozer
hi, i am just working on that board.
I have picture
running ASD and select Video Controller internal i get in the first(open GL point test) a Failed
if i run the same test now for video controler external this open gl ... test is passed
after that again running only for internal and it passes through without problems
c9560 is replaced already
if i plug in an external monitor there i have no picture
sometimes asd running it shows only the test for external controler
is it a good idea to reball the gmux?
ALB-Repairs
just spend ages picking of the edge bonding and ensure theres none under the chip, then a reflow will do the trick, Much easier than reballing.
