bighead
Hello,
This was a liquid damaged unit. I changed LP8550 and LCD connector.
Now I have backlight. Only problem when I set the brightness it's not smooth, it's not continues.
It's "flashing" laggy when I set the brightness. I didn't really have this problem before.
Only blacklight problem I had it was no backlight, or I could see the leds at the bottom of the LCD.
Changing the backlight sense resistors always solved that, but this is different now.
The second problem is that when it goes to sleep mode, it won't come back, if I press any button on keyboard.
It just comes back if I press the power button. I have PP3V3_S4.
Thank you.
Thank you.
