[SOLVED]820-3115-B LED fades to none and only after battery disconnect shows indication.
Davis
I replaced dcin, magsafe and battery and same symptoms..
only after disconnecting battery and attaching magsafe and battery back i get sometimes indication lights but it fades very slowly to 0, if I cover LED i can see very weak green light pulsing.
no corrosion.
So you mean there is no green light? Battery is not needed for this and can be left disconnected for now.
What is you PPBUS voltage? 12.3 or 12.6?
