[solved]820-3115 Battery indicator connector
Status
Not open for further replies.
XooP
Got a 820-3115 today that would not charge or run of the battery. The board was water damaged around the battery-indicator connector. Removed the connector and replaced the components around.
The board now runs fine and the battery is charging. My problem now is, where do I get hold of a new battery-indicator connector?
aprendiz
Moderator
Take it from a donor board, in order to remove the connector use a lot of flux and apply heat with hot air at max from the back of the connector....
JorgePayar
XooP
What do you mean Louis? How I got it off with a knife or if I got it to work?
Well, it works now :)
Status
