[SOLVED]820-3115 No V-core
Status
Not open for further replies.
ALB-Repairs
820-3115 with no V-Core.
Origianly damage to the TON resistor (TON A AND TON B) Replaced these resistors and U7400.
The resistor values are correct but pin TONA and TONB is 0v
ive seen this caused by the pch before but this isnt a 100% certain solution as i have tried on other boards and not made any progress.
Enable and VIN are both present.
ALB-Repairs
Yes, Yes and 12.6V
We are only looking at the V-core circuit. We have ALL_SYS_PWRGD, which is one of the last signals to come up before the V-Core circuit is enabled.
arghhh
Well TON comes from PPBUS_G3H, so check for a broken trace to those resistors.
What's the voltage on either side of R7402/3?
ALB-Repairs
No! have you ever done that? all the V-Core mosfets fail, it sends 12V to the CPU. Its down to signals between the SPI, PCH and CPU i think. As stated above i have seen the PCH cause this before, but i think it also could be a dead CPU.
larossmann
For me it's always some corroded solder ball under PCH if not U7400 that reflow fixes. It's hard to see under that chip with a microscope due to position.
ALB-Repairs
Physical damage by previus owner. L2451 replaced L2406 replaced. Both supply the PCH with voltages.
all problems solved.
Status
