[solved]820-3115 Permanent Optical Output
Status
Not open for further replies.
rzeszu
Hi
I have a problem with this board.
I repair power problems after liquid damage but after the test and found a problem as audio on a photo.
When power on i have chime.
Could you help me with this issue, what you suggest?
I have a problem with the motherboard.
I fixed a problem with the power supply after liquid damage, but the study found a problem with the sound, as in the photo.
Can you help me with this problem, what do you suggest?
Kindly Regards Mariusz
larossmann
If there is a red light coming from the audio jack, shove a toothpick in there and try to hit the switch inside the jack until there is no more red light.
rzeszu
No red light, hp ports seems to be ok.
But i check only short on pin 1 and 2 (J6700)
Is there any other way to test this port?
Status
