[SOLVED] a1278 2936 low volatage on ppbus_g3h is 1.6volts
Status
Not open for further replies.
djpat1974
Hi, i have and A1278-2936 Board with green light at the charger.But ppbus_g3h is 1.6volts i even change u7000 and still same problem.What do you recommend? Please see my attachment for the rail i have checked.
djpat1974
thanks for your reply on f7040 to ground the resisitance in diode mode 0.423 current sensing (pins 27/28) is 16.31v and pin 17/18 i get 1.4v
djpat1974
Hi, i get 16.31v on pin 27/28 and i get low volts on pin 17/18 i should have 12.6 on pins 17/18 but i dont can you help me with this
I have no idea what you mean. Check R7021/22 if they are 10 ohm and then check all traces from ISL6259 to R7021/22 and to R7020.
djpat1974
okay i got some where wow you were right r7020 resistor had a bad trace that would not give me ohms reading on r7021/22 now i get 20 ohms after i made a jumper from r7020 i get now 12.6 and fan spins the only problem now mac come on then shuts off then comes on for about ten seconds i tried to smc reset and pram didn't work am thinking bios or maybe something i miss over look what you thing and thanks so far.
Status
