If you reffer to MCP79/89, be aware that you cannot expect too much from such chips, with more than 10 yo.
Measuring the resistance to ground on 3V42_G3H is a good method; use ohm scale, not diode mode.
A value lower than 30K, usually means bad MCP...
Hi, I would like to know is someone have the solution to test GPUs before using them , to avoid lost of time and failures and to loosing time to reball a bad chipset. As all the chipsets from China are craps, I've seen that for the Xbox 360 and the PS3 some people use a Ω test to test the die...
