thread top ad
Collapse
Announcement
Collapse
See more
See less
820-00165-A - Turn on, but no chime
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • 820-00165-A - Turn on, but no chime
    Turn on, but no chime or back light.
    Have light on the mouse
    Where i can start troubleshooting?
  • #2
    Update:
    I just pull out the J6100 and
    Works, but after 1 minute shutdown
    Comment
    • #3
      PPVCC_SO_CPU: 1.8v before shutdown
      Comment
      • #4
        Plugged in AC? Shutting down when booted in OSX?
        Comment
        • #5
          Yes. When i get the Osx shutdown, also even without system, after 30 seconds shutdown.
          Comment
          • #6
            Corrosion somewhere....
            Comment
            • #7
              Just on J6100, but i take off
              Comment
              • #8
                Any idea where i can start troubleshooting?
                Comment
                • #9
                  Yes, find the corroded resistor or trace, can be anything.
                  Comment
                  • #10
                    The board is really clean.
                    Comment
                    • #11
                      Great, look harder, could be under SMC, pin 8 of U1950, whatever.
                      Comment
                      • #12
                        U1950 Pin 8 3.4v and looks ok, i think.
                        I just re-soldering and right now no more chime, back light and don't shutdown.
                        Comment
                        • #13
                          dukefawks any hint?
                          Comment
                          • #14
                            So what changed, you already had no chime and it powered on......
                            Comment
                            • #15
                              1 - Turn on, but no chime or back light
                              I pull out J6100 and then i get chime, back light and OS, howaver after 30 seconds shutdown.
                              2 - You told me could be under SMC, pin 8 of U1950, whatever.
                              So, i check and re-soldering. But after that, i don't get OS, also chime and back light.
                              Make sense to you?
                              Comment
                              thread bottom ad
                              Collapse
                              Working...
                              X
