2011 A1286 repeating hard Drive Failure
Ryanlen2
I have a 2011 A1286 that is back for the 3rd time due to hard drive failure. Partition is unrecoverable. I have tried EasUS and Disk Drill so far. My question is, is it possible for a board or cable to be causing this recurring problem? I have replaced the drive 3 times like i said. Thanks for any help in advance.
Inwerp
cable failure could be easily diagnosed with SMART. check for CRC errors, this counter shows controller <--> HDD data line errors. if smart is ok, next step is to change it to SSD. it could be simply the customer's behavior - i hade one with a habit of tapping rhythms on the palmrest. :rolleyes:
also, for HFS+ repair I strictly recommend you Disk Warrior, this utility works literally like a charm when diskutil fails.
Bad sectors are not caused by the machine. You either have bad luck or you are getting crap drives from someone or this guy is knocking this thing around. Swap a SSD in there and then in 3 months he will be back with a dead GPU.
