4924 - Huge liquid spill, no power.
gcain
It was soaked. Board is in okay shape considering
Green/Orange light okay. Originally I was only getting 1.6v on PBus. Sent it through the UC and now PPBus is right, still no power.
Voltages in no particular order:
PP_VRTC_G3H = 3.4v
PP3v3_s5 = 3.3v
PP5v_s5 = 5.02v
PP3v3_s4 = 0v
PP5v_s4 = 0v
R8115 = 0v either side.
PPBus = 12.58v
PP3v42 = 3.42v
L7560 = 3.4v
L7520 = 0v
aprendiz
Moderator
Check if you get any pulse on L7520 after connect charger, may need osciloscope.........
Check corrosion around U6100, J6100, SMC...
Resistance to ground on L7520??
gcain
I don't have access to a scope unfortunately.
U6100 and the J6100 look great and beep out ok.
SMC looks spotless, even probe points aren't discoloured.
The only hint I could see is it looked like there was grime around the Camera chip (U3900) so I sent some flux under it.
Resistance to ground on L7520 never stops counting. It reached 5MOhm at one stage.
gcain
I can actually pick up a pulse on L7520 when I first connect power.
P5V3V3_VREF2 == 1.99v, is that right?
The board was soaked.....so where was the corrosion? The usual suspects apply, U6100 and traces/resistors, J6100, U1900/50 and possible crap under the SMC. Also check CPU Vcore resistance to GND.
gcain
I got the board in under and hour and it went straight into the UC or I couldn't work on it.
Only corrosion I can spot is around C7622, C7317 and C7202. They're all HS_COMPUTING pretty much and all measure 12.58v
U6100 looks good and does the jack.
PPVCC_S0_CPU (Is that VCore on this board?) is 0.3 and 0.4 Ohms to ground
I'll flow some flux under the SMC in the mean time and see what happens.
