800 MHz problem with 820-2915
Thorsten
I am not new to component level repairs but also not a pro at all. Have done some work and still learning. The machine I am talking about today is a friends 2011 MBP that I am trying to diagnose and repair. To make a long story short: All I know is that the battery was swapped for a new one and since then the machine is stuck to 800 MHz according to Intel POWER Gadget.
I know that this board need the battery for full performance. Battery is "seen" and does work. R5280/R5281 measure 2k.
Tried to swap the battery again for a known good -> no fun, same situation.
So somehow the SMC does not see the battery in a manner that it allows the CPU to work full speed while the battery is seen clear enough by whatever else to charge, run off the battery, show stats, use Coconut and os on. Seems that I am missing something. Any help? Thank you in advance!
Edit: I forgot to mention that the 3S144 ASD does not throw any sensor related problem (no problem at all to be precise).
Thorsten
Thank you for your answer, Duke. I am not sure what you're trying to tell me. I wrote that I replaced that battery with another battery that was and still is "known good" to no avail. Same problem. So how do I have to interpret your answer, Duke? Thanks.
EDIT:
I have read the schematics a little bit more in detail. There is a signal "prochot" that seems to be a pin at the CPU that either tells the CPU to throttle down to 800 MHz (when set by the SMC) or signals back to the SMC if the internal temp sensors detect an overheat of the CPU. Page 45 of the schematics has information on how SMC and CPU interact (SMC FSB to 3.3V level shifting). Given that the sensors (HWmonitor and also hardwaremonitor) do not report ANY obviously wrong reading and also given that the ASD does not throw any problem for any sensor we could safely assume that the sensors should NOT trigger that signal. But we are running at 800 MHz flat. That's a prove that prochot is active, right? So what might cause this? Defective SMC, defective CPU or any of these components on page 45? I am not sure about the latter, can anybody have a look and see if there is a candidate for my problem? Usually I would say that the battery (I2C) and thus the SMC is to blame for a triggered prochot. But the battery is seen and there is no sign whatsoever that the battery is to blame for the 800 MHz slowness. What IS to blame is a triggered prochot, that's for sure.
Bonus question: Has anybody already tried to hardwire the prochot signal? Effectively disable the SMCs ability to throttle the CPU? Might not work as there might be power regulation involved, too, I know. But that's only a fun question...
smiba
Only proof is to probe it and see it yourself. I am not sure this might be the issue but feel free to proof me wrong! Always a first time for everything :)
Are you using ASD OS or ASD EFI?
smiba
The CPU_PROCHOT_L signal is active when the voltage on this signal is logic low (So anything close to 0v). So Low active, yes.
To see if this signal is being pulled down by the SMC check the SMC_PROCHOT signal. If SMC_PROCHOT high Q5059 will pull CPU_PROCHOT_L to ground which will cause it to be low.
What is the voltage of CPU_PROCHOT_L and SMC_PROCHOT?
Also check out ASD OS, it can do a couple of other tests that can be of use.
I have no idea. This is one of those the machine works don't mess with it. Be happy it runs on low clock, the GPU may last another 3 months instead of 3 weeks.
Last thing to try is have you ruled out software, are you comparing an exact identical machine? Power gadget may be buggy and report BS.
