820-00138-A Shuts itself down before booting to system.
Beto_MFC
Replaced U7200 (CPU VR12.5 VCC Regulator IC) and caps C7210, C7211 and C7212. After that, system doesn't power off but I get no vCore. CPU cold as a corpse...
Beto_MFC
Just swapped a cap and a resistor by mistake. Very hard to solder 0201 components without microscope. Will fix and get back here. It will be the first time with the replaced U7200. But that error made me have sure that is the U7200 circuit or some cpu feedback that is making it turn off.
Beto_MFC
Ater I swapped all 3 phases of the CPU VCC regulators, it won't turn on. I noticed that the inductor L7130, which is for the battery charger gets hot when ac connected. Can I blame a bad CPU yet and discard this repair?
Beto_MFC
Don't think so. If anything, this board doesn't get vCore at all. After the last VCC regulator swap it stopped working, Will give it a last try as the inductor has nothing to do with the 5v rail that power the CPU.
Beto_MFC
Confirmed. Pulled off U7310 and it worked again same way as before (turn on then off after some time). One phase of the CPU got fried. Destination: Trashbin.
