820-00138 can't power on or off on keyboard or power pads
Do some resistance measurements on the different points where you can get to SMC_ONOFF to the KBD connector pin.
PP3V42_G3H is short to ground i measure in diode mode on pin 1 on R5170 I get 0.7 and measure on pin 2 i get 0.068. Any ideas what to do ?
I checked 3 times in diode mode the red probe on ground and measure with 2 different multimeters same result. I'm really confused
Well something must get warm with such a low resistance. Feel around the board, SMC would be a good suspect.
I still don't see how the board can work. If resistance to GND on 3V42 is 0.06 Ohms then the current would be 3.42/0.06=57A!
Is the battery and AC really disconnected when measuring this?
Also check resistance to GND on L7095
Everything is disconnected no power no battery and on L7095 resistance was same. So i got power supply from old desktop computer and i inject 3.3v and didn't change anything and after i inject 5v and after that was showing me 0.2 resistance but now dropped to 0.1 resistance and the board is still turning to OS
You inject 5V on a 3.4V bus? Please, what the hell are you doing??
I have no idea what you are doing anymore. If you inject 3.3V on a 0.1 Ohm short something will start getting hot.
i injected 3.3v on PP3V42 nothing was hot after that i injected 5v on same rail PP3v42 and the resistance from 0.06 went up to 0.1
Let me do some Ohms law for you. I=U/R, I=3.3/0.1=33Amps. I'm curious to see what power supply you are using that supplies 33A. Also smoke should be coming from somewhere and there is NO WAY this board can even have a green light. P=U*I P=3.3*33=109W. Something must be dissipating 109W which is some serious heat!
I have no idea what you are measuring or doing so I can't give any more advice at this point. Is this board even working at this point?
