820-00138 - PPBUS_G3H Shorted to ground, also PPVIN_S5_HS_COMPUTING_ISNS
nelo1012
hey guys
820-00138, very minor liquid damage at U7310, on pin 8, 9, 10, 11, 12, 13, 14, and the small capacitors around there, replaced everything, except U7310, PPVIN_S5_HS_COMPUTING_ISNS short to ground, Diode mode shows 0.000,
also PPBUS_G3H is shorted to ground as well, when i plug in the power cord, CPU Warms up,
Dead CPU? or do you guys have any ideas? Should i replace U7310 First?
also i took out U7310, and Pin 43 is Showing 0.000 at diode mode
Thank you guys in advance.
