820-00164 no backlight
peterfixit
macbook air came in with corrosion over the j8300 and surrounds as well as u7701, I replaced J8300 and u7701 and now have no backlight
history was an entire glass of milo was spilled on it
with a torch shined through the apple logo we get folder icon
PPHV_S0SW_LCDBKLT is 10.92V
SMC_LID is 3.422V
OK if you say the trace is good then put back a LP8550. Then check BKL_EN and PWM. Check traces from B1 and B2 also for continuity before putting chip back.
Do a PRAM reset. Then if there is an image on the LCD and SMC_LID is high, EDP_BKLT_EN should be high too. Could be a bad LCD assembly too...
