820-00165 don't turn on from battery
mobajer
Hello, one more interesting issue. 820-00165 had missing battery connector and little water dmg, now everything is solved. also was some shirt under ssd I have reballed.
ppbus_g3h present
smc_onoff_l present
Macbook turns on and works from charger.
when tunes on, can unplug charger and it works from battery. also can be turned off if power button from keyboard.
but if try turn on only with battery plugged, nothing happens.
what voltages should I also check?
Is the battery properly recognized in OSX with charge cycles and stuff showing? Is the battery charging in OSX?
