820-00165 Green/Orange without battery, No liquid Damage
Inwerp
Hello everyone
Charger light works normal without battery. With battery attached it stays green.
SMC Reset changes light like it supposed to.
Energy consumption: 0.04 amps
S5 rail present, SMC_BC_ACOK high
S5_PWRGD High
PP3V3_SUS present
s4 rail is as dead as Steve Jobs.
i do not really understand how S4_PWR_EN is generated
in schematics it goes from U8170 NOSTUFF AND chip, AB is PM_SLP_S5_L(0V) SMC_S4_WAKESRC_EN(0v), both are low.
I have already desoldered bios chip and tested if i can read it. re-programmed it with "clear me" bios, nothing really changed.
Now i'm trying to test clock signals to BIOS chip with a cheap Oscilloscope, but i do not really know if 20mhz is good enough for this purpose.
Please don´t tell me SMC is dead - i have a greenlight and SMC Reset indication. :)
Inwerp
well, genuine 19V with "60-watt" chip :)
of course, i have a genuine brick too, but i don´t believe it could get S5_PGOOD if something was wrong in this area.
Inwerp
so it looks like this model has some weird relationships with the battery - i have found several posts on Russian forums, people claim that it does not autostart with no battery attached. This also means that if the battery died (overdischarged, for example), we will have this strange behavior. I guess Lous has rage-broken such board in some of his videos, thinking it is the CPU.
can someone confirm if 00165 starts without the battery?
For me they always do, but I have read that for some they don't. So to rule this out get a known good battery that has a charge.
Why are you messing with U6100 now? I doubt that will be the issue if Vcore is not even there. You can just try any 00165 dump for testing first.
Inwerp
well, from my PC laptop experience i know that unreadable/corrupt bios may be the cause for dead Vcore/permanent S5 or even no charging light on some Compal platforms.
first thing i did with this board is i tested all rails and mosfets for shorts. this board has zero hints.
so is that possible that SMC override starts brain dead board and Vcore absence shows that CPU does not answer to its controller to set Vcore voltage?
i mean, sorry for such a stupid question, but what exactly is being overridden?
i'm getting really close to write "dead cpu " on this board :confused:
It is possible that the BIOS is corrupt, but unlikely. Just try another 00165 dump and see if it works. IF that solves the issue we can deal with ME region and serial numbers.
