820-00165 wifi issue
mobajer
Hello, I have 820-00165 which had slight water damage and was not turning on at all, was changed some corroded resistors and reballed SMC. Now it fully works, but has no wifi and cooler spins on max RPM.
please help, what algorithm should I go throw? Thank you
mobajer
No Title
on pubs_g3h I have 8.6v without battery. tried other touchpad and keyboard+flex, 2 errors gone :) only wifi left.
but tried wifi boards, its problem in main board.
ielectron
i had similar issue, U3550 wifi switch was shorted to gnd. I had to replace the wifi card too, it was shorted too and that killed U3550, before u replace it measure both sides to gnd if 0 ohm or not
