820-2262 - no power, no MagSafe light
mikiotty
7.5Kohm 19/20 (seems a bit high...)
2.6Kohm 21/22
No short on Q7901/02.
D7903 diode mode:
- positive on pin 1, negative on pin 3: .595
- positive on pin 3, negative on pin 1: .793
Should I replace D7903 and the resistors on 19/20?
Sorry for all the questions, I'm quite new to this stuff!
Vogelek23
Is R7906 supposed to be 2.2ohms or 2.2Kohms? Is it a typo in the schematic?
No typo on the schematic - this is a filter resistor (along with C7902 it does reduce the switching noise) so it is of such low value.
R7904 is about 7 ohm (should be 0)
R7905 is 5.7 Kohm (should be 18ohm)
R7906 is 2.6 Kohm (should be 2.2ohm)
Of course all of these resistors must be replaced according to the schematic.
