820-2330 (Gross) Fails ASD, Gmux.
SMMRepair
I normally don't take boards older than 2011 for repair, but did so as a favor to a friend. 820-2330 that had the common C7771 failure. Replaced the cap, and had ASD running and it failed the Video Controller Internal (test #40) - Gmux Switch to IG. Should I disregard this, or should I go ahead and heat the Mux up a bit? Computer seems to work fine in OS; I don't see any option to switch graphics in System Preferences (but I'm unfamiliar with this board--should there be an option in Energy Saver to do so? If so, is the fact that it's missing a sign that there's a Mux issue?).
Thanks!
