820-2523 Kernel Panic?
Fizzl92
Hello
this 820-2523-B boots up normally until it nearly finishes loading. Then it shows the attaches picture, shuts off, turns automatically back on and repeats this process. If i want to install OSX with an usb drive it works until i go to the "disk utility window" where i normally can create partitions or wipe the drive. In this window, before i can see any drive information, it keeps spinning the "colored wheel" - with different drives ans drive cables same thing. The strange thing is that it will boot up normally with a drive from another Macbook with OSX already installed. I´m really not sure what to do with this one but my guess is Kernel Panic and C9560 but i´m confused because it works just fine with the other drive. Or could it be a to new version of OSX for this machine on the original drive? Thanks for any help.
I tryed different ram but its doing the same thing with 2x1GB PC8500 too. Also it sometimes displays the "Your computer restarts because of a problem...." message that i attached after shutting off and back on.
