820-2530 - working but slightly high fan spin after U7000 replacement.
Alan.L
ASD EFi showing battery sensor temp error.
logic board is working great, can charge and see the battery, but fan spin is abnormal. ive already tested with couple of known original working battery and still same.
coconutbattery app show all the info fine, even battery temp is fine too.
should i leave it or has to be repair?
Battery will not cause high fan spin, it should run normal without battery connected. Run ASD again without the battery and see which sensor fails.
