820-2610, C7771 repaired ok but now Single beep.
hi duke,
this is an old whore so its definitely fucked by others - I checked R5200 and R5201, diode mode 0.490, 3.33 to 3.40V when powered on. I also removed the flex from J3500 to no avail.
after 4-5 tries it stopped beeping and R5201/02 (SMBUS_MCP_0_DATA) reads 1,1V momentarily - same time the fans seems to pause for a few mseconds - like a restart (it doesn't chime so cant tell for sure).
couple of tries later the beeping is back.
fucker.
yeah I suspect the MCP too... since I have the tools for an easy MCP swap I will give it a try and if that fails this board goes ..well you know where.
thanks a lot dude.
