820-2610 screen goes blank and shuts off intermittently
WeLoveApple
So we got a mpb 17 with this board.
At first the machine would not even start. By watching multiple videos where Luis addresses this issue I was speculating immediately that the "classic" C7771 cap issue will be the problem.
Measured voltage on it, it was 0.3V. Changed the cap to a non tantulum one.
The machine would start up. It seemed that we fixed it but when the owner came back and installed own ssd and optibay the machine would turn itself off just after boot.
When we try to boot from external hdd it works. Also tried connecting multiple usb devices that suck power but it would work fine. But when we boot with the hard drive installed in still shuts down every now and then.
Another issue that might be connected is that the screen will turn itself off quite oftenly. Tried felxing the motherboard just in the area above the fan where the vRams are and the screen would go on and off.
Measured all rails, everything seems normal.
No idea where to look next.
Thanks for the help
U9600 is a common problem. You can try to reflow it, but that does not always work. Pulling it and rebelling it is the best solution. I would advice to practice on a scrap board first!
