nate8organic
got in a 820-2849 appears to have been cleaned. ppbus_g3h giving me 7.65-8.5v with charger plugged in. it bounces around slowly from 8-7 or 6v and then back up to 8 something. battery only is 1.5-2 volts. and it wont stay a steady voltage. checked the res on pin 27-28 and 17-18 on isl swapped the isl with a good one same thing. will not power from battery either. i have pp3v4_g3h. r5403 does not look good its giving 0 to .03 volts not that it should be putting out voltage necessary. im finding some corrostion and obvious liquid around the l6707 up the board d4610 right next to the smc. i did a smc by pass and nothing happened.
not sure if these symptoms have any obvious part / place to look or if need to just check every rail.
Thanks
Nate
Thanks
Nate
