Had checked briefly what was obvious to me on U6201 before I posted. And saw someone suggest U6630 from a Google search. So I guess I was fishing. This is the same board that I just had the BL issue with U9600. Will check your suggestions. Thanks for the help guys.
Hi... All recommended components to check are good. I did have to replace DZ6700 and DZ6704 because the where both cracked but these are for audio jack. Other then that everything looks OK. Thanks.
So I replaced U6201 and audio did start to work. After I shut it down and restarted it the audio did not work at all. I'm guessing that t isn't the chip itself but like you said a component around it because it seems like by heating up the area when I replaced the chip is what made it start working. Tantalum capacitors? Thanks man.
