820-2850 PPBUS_G3H Trolling Me
supamodz
Working on a 820-2850, customer stated i was doing a party and mac dies in the middle of the session. When i opened the back cover and plugged in the charger the fans are pulsing, not spinning only pulsing. so i started to check the power rails, and ppbus_g3h voltage keeps dropping. It will not stay a solid 12v , it drops to like 4v and spikes back to 12v. I checked current sensing resistors all of them, replaced isl chip same problem replaced transistors, i removed the fuse and checked pin 1 for a short no short i checked caps around area no short I'm completely lost. With fuse off i plugged in the charger and checked pin 1 for voltage same 12v droops to 4v and back up again no water damage board looks fine.What the hell could be the problem here. Please i need help.
Yes duke i tried with a battery and it won't turn on i read the battery voltage as well i get 10 volts at the fuse steady 10v no pulsing just wont turn on.
I'm suspecting something in the TPS51125 circuit. Check if the enable P3V3S5_EN is pulsing and if 3V3 output is actually coming high. U7940 is generating RSMRST this way.
Duke your absolutely right, P3V3S5_EN is pulsing. So what could actually be causing enable to pulse in the circuit? In the schematic it says it comes from SMC_PM_G2_EN does this mean bad smc, or something telling the smc signal to pulse.
Hardly any power to cpu vcore at all, max voltage 0.030 and back down to 0.000 and back up again you can sort of say its pulsing but not with the proper power.
no its dead hardly putting out any voltage i doubted it would be on because it needs 3v3_s5 to open the gate
Well, one of the power rails is not coming on, so it is pulsing. Check all coils and see which one does not pulse, that one is probably keeping ALL_SYS low.
These are the readings im getting im confused as hell [TABLE="border: 0, cellspacing: 0"]
[TR]
[TD="align: left"]PPBUS_G3H[/TD]
[TD="align: left"]pulsing[/TD]
[TD="align: left"] [/TD]
[/TR]
[TR]
[TD="align: left"]PPBUS_CPU_IMVP_ISNS[/TD]
[/TR]
[TR]
[TD="align: left"]PPDCIN_G3H[/TD]
[TD="align: left"]17-18V[/TD]
[/TR]
[TR]
[TD="align: left"]PP3V42_G3H[/TD]
[TD="align: left"]3.41V[/TD]
[/TR]
[TR]
[TD="align: left"]PP5V_S5[/TD]
[TD="align: left"]PULSING[/TD]
[/TR]
[TR]
[TD="align: left"]PP5V_S3[/TD]
[/TR]
[TR]
[TD="align: left"]PP5V_S0[/TD]
[/TR]
[TR]
[TD="align: left"]PP3V3_S5[/TD]
[/TR]
[TR]
[TD="align: left"]PP3V3_S3[/TD]
[/TR]
[TR]
[TD="align: left"]PP3V3_S0[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V8_S0[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V5_S3[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V5_S3RS0[/TD]
[/TR]
[TR]
[TD="align: left"]PPVTTDDR_S3[/TD]
[TD="align: left"]When I test this probe fans completely stop pulsing[/TD]
[/TR]
[TR]
[TD="align: left"]PP0V75_S0_DDRVTT[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V2_S0[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V05_S0[/TD]
[/TR]
[TR]
[TD="align: left"]PP3V3_S0GPU[/TD]
[TD="align: left"]0.004V[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V8_GPUIFPX[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V8R1V55_S0GPU_ISNS[/TD]
[TD="align: left"]0.00V[/TD]
[/TR]
[TR]
[TD="align: left"]PP1V05_S0GPU[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_GPU[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_S0_CPU[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_S0_GFX[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_S0_CPU_VCAP0[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_S0_CPU_VCAP1[/TD]
[/TR]
[TR]
[TD="align: left"]PPVCORE_S0_CPU_VCAP2[/TD]
[/TR]
[/TABLE]
I just read you tried a charged battery and PPBUS is 10V? A charged battery should be way over 11, confirm again if this machine is also dead with a known charged battery.
Hey duke i tested it with a different battery, I get 11.07 v at PPBUS_G3H steady. When i try to turn it on the fans pulse, as soon as i release from jumping pin 5 on the keyboard connector it stops.
i get what your saying, but where should i start duke. Should i pull coils one by one to see if my voltage gets stable or pull controller chips one by one to get a stable voltage. How would you handle a mess like this?
Put multimeter on coil and see if something is there. Could also see if you can disconnect the PGOOD signal one by one.
