820-2879 Green light no start
Cocobill
Hello,
an 820-2879 came in with minor water damage around Q9807 area.
green light OK
ppbus_g3h 12.52v
PP3V3_S5 OK
Does not boot. What do I measure first?
Thank you
That may be a bit low but now 100% sure. Look carefully for corrosion around U6990, did anything get liquid around that? Battery charging?
Checked all rails for shorts? Any corrosion around the TPS51125? PM_PWRBTN_L doing anything when you press power button?
Cocobill
Found short in ppvcore_s0_cpu line, diode mode is 0.014v. Also ppvcore_s0_mcp is 0.015v. No corrosion around TPS51125. PM_PWRBTN_L is going from 3.3v to almost 0 when shorting SMC_ONOFF pads.
Resistance to GND is the only way to check for real shorts. Diode mode measures a voltage drop, not quite the same.
