820-2879: PPBUS_G3H drops slowly from 12.4 volts
pauly341
Greetings. I'm having this similar issue with multiple boards and I always end up chasing my tail - so wanted to start fresh before I started replacing stuff.
When the board is connected to AC only, PPBUS_G3H measures 12.4v but then starts decreasing by about 1 volt per second. No issue once battery is connected. On other boards, I've replaced u7000, u6990, multiple resistors and caps around these ICs but no luck. Should I be thinking about some other type of component failure such as a coil?
thanks,
Paul
pauly341
17/18 = 2.9 ohms
27/28 = 20.2 ohms
It does power on from a charged battery
discharged for about 4 hours
