820-2915 no power fan spin 3 secondes and stop loop
aurel476
Before replacing gpu i've heated gpu and board starts ok
After replacing gpu twice, same probem, fan spin 3second and stop loop
Good light, orange light ok
Glue under vram removed before and checked balls after
Garbage gpu?
No composant missing or burned
PPVIN_S5_HS_GPU_ISNS 12.56V
Another point to check?
Ppvcore_s0_cpu 0v (short to gnd) :/
gpu vcore up to 1v about and 0 when fan stop
SMC_CPU_HI_ISENSE 0.8V
ALL_SYS_PWRGD up to 3v about (too fast for read next)
1) Where did you get the GPU and which date code?
2) You can remove the GPU, these boards will boot up without one, there will of course be no image.
date code 1532 garbage ^^ ?
What are the good date code for you ?
I will try without gpu if board start
cpu not too heated because for test i've reflow gpu first same temperature before replace, and cover CPU with adhesive high temp,
Balls touch under vram can cause this ?
Ppvcore_s0_cpu always 0V?
You can try to pass with your soldering iron some leaded solder at the pins of U7400
Why would you do that? Makes no sense that would be an issue after GPU replacement. CPU need to talk to U7400 to enable it, CPU is dead so no Vcore.
Always 0V PPVCORE_s0_cpu, U7400 fine
i've probably fried CPU because GPU is proximity (overheat)
