820-2915 No Video
Ryanlen2
Hi. This board chimes and boots. No internal external video. No liquid damage. Missing PP3V3_ SW_LCD. LCD_PWR_EN is 0.12V. No short on line. (.537). Heated GPU to 100 C. No change. Thanks, have a good one.
GPU voltage should drop down to 0.9V once GPU is initialized. Was this thing already messed with? Check all the caps in the PCIE lines to the GPU.
Ryanlen2
Edge bonding is still in tact. No burnt up probe points or caps on board. Only thing not original was thermal compound. I will check your suggestion. Thanks. Have a good night.
Ryanlen2
C8145 - pin 1: .293 pin 2: 0
C8146 - pin 1: .293 pin 2: 0
C8147 - pin 1: .293 pin 2: 0
C8148 - pin 1: .293 pin 2: 0
C8149 - pin 1: .293 pin 2: 0
C8150 - pin 1: .293 pin 2: 0
C8151 - pin 1: .104 pin 2: 0
C8152 - pin 1: .104 pin 2: 0
C8153 - pin 1: .104 pin 2: 0
C8154 - pin 1: .104 pin 2: 0
C8155 - pin 1: .104 pin2 : 0
C8156 - pin 1: .104 pin 2: 0
C8157 - pin 1: .104 pin 2: 0
C8158 - pin 1: .104 pin 2: 0
Thanks Duke.
Ryanlen2
ohhhh. Well that explains a lot. Sorry. To be honest I saw PCIE on pg 74 and thought thats what you were talking about.
Ryanlen2
C8020 - pin 1: .357 pin 2: .783
C8021 - pin 1: .355 pin 2: .785
C8022 - pin 1: .359 pin 2: .786
C8023 - pin 1: .354 pin 2: .786
C8024 - pin 1: .357 pin 2: .786
C8025 - pin 1: .352 pin 2: .786
C8026 - pin 1: .360 pin 2: .787
C8027 - pin 1: .351 pin 2: .787
C8028 - pin 1: .362 pin 2: .786
C8029 - pin 1: .357 pin 2: .786
C8030 - pin 1: .359 pin 2: .787
C8031 - pin 1: .352 pin 2: .787
C8032 - pin 1: .359 pin 2: .786
C8033 - pin 1: .357 pin 2: .787
C8034 - pin 1: .359 pin 2: .787
C8035 - pin 1: .350 pin 2: .787
C8055 - pin 1: .424 pin 2: .379
C8056 - pin 1: .424 pin 2: .385
C8057 - pin 1: .424 pin 2: .413
C8058 - pin 1: .423 pin 2: .410
C8059 - pin 1: .423 pin 2: .383
C8060 - pin 1: .423 pin 2: .410
C8061 - pin 1: .422 pin 2: .382
C8062 - pin 1: .423 pin 2: .382
C8063 - pin 1: .423 pin 2: .378
C8064 - pin 1: .423 pin 2: .384
C8065 - pin 1: .423 pin 2: .510
C8066 - pin 1: .423 pin 2: .384
C8067 - pin 1: .423 pin 2: .376
C8068 - pin 1: .423 pin 2: .381
C8069 - pin 1: .424 pin 2: 1.281
C8070 - pin 1: .424 pin 2: .384
Pin 2 of C8069 seems comparably off.
I changed C8069 and now I have pin 1: .426 pin 2: .402
Unfortunately this is one of the boards I put into the U.S. mostly working, and came out non working. Not chiming now. Working on getting it going again.
