820-2915 Question
macitech
Hi
I have a early 2011 MacBook Pro 2011 goes through book process and all works until it gets to last screen which is BLANK White.
I tried a different drive but same result.
Im going to replace the tangent capacitor but has a different number then previous on.
I am going to replace with a 330uf? Scamedic says 220uf
Attached is a pic of the old cap on board.
Thanks
aprendiz
Moderator
the only thing you need to replace is GPU...... Apply some heat to the GPU and test again, I bet it will boot !!
aprendiz
Moderator
Maybe yes but not because of the replaced cap, will work because of the heat applied will reach GPU and bring back to life a zombie....:):):)
