820-2936-b won't turn on (quarter fanspin)
WeLoveApple
Liquid damaged board had been worked on already. Possibly SMC reball and other repairs.
Current state:
Green light, all hot and S5 rails present.
SMC_BC_ACOK is present.
R7005, R7021/22, R7051/52 are fine.
Board is looping with quarter fanspin.
Any idea where to look?
R7402 is fine. R2806 near clock chip was gone. Replaced that.
Clock chip was looking kind of okay, two pins were darker. I have no replacement from donor board so got it off and soldered it again.
U5410 was missing so put one on.
Nothing changed. Still repeated quarter fanspin.
Should I replace clock chip with a new one? Problem is I only could find some on air boards. Is there a chance that they will work?
Checked schematic of a 820-3437 board and clock chip looked identical so put it on this one.
This time it turns on but no chime.
CPU vcore is peresent.
Well that is bad. Could be anything, probably corrosion under SMC/PCH, but any corroded trace/resistor can cause this. Did you check without the RAM if it beeps? Speaker in the case must be connected, not the one on the board.
No idea, could be anything. As I said, the clock chip was dead so there was liquid there. SMC is right there too, so maybe crap under it.
