820-2936 - Corroded LVDS connecter. No image after replacing.
gcain
The LVDS connecter was burnt out and corroded through. I have replaced it twice.
Laptops chimes and works on external display. It gives me a backlight and thin white line down the bottom. Like the image has been compressed into a 2px high line. It is also doing a scan effect with the backlight. Hard to explain and I can't get a picture of it.
Customer is losing his mind over this one. :/
But I just can't seem to get the picture back.
jadao
No thats doesn't look right.
did you put a 2012 lcd in 820-2936?
it s same pinout but diferent connectors...
there is a little gap when you insert the lvds it s easy to short with neighbor pins...
last time I did that L9004 burned because pin 2 lvds touched pin 1 on connector.
gcain
L9004 seems to measure okay.
Will replace L9080 in the mean time, can I replace it with an L9080 from 2530?
All my 2936s are missing their L9080s already.
gcain
Thanks Jadao,
Just before I saw your post I was starting to think it might be the LVDS jack causing a short. There really isn't anything else.
I'll replace it in the morning and report back.
