820 2936 - don't Show image
Noguinfor
Hey,
This machine does not show image. I think it should be because a peak off current in E - NET CONN.
Q4262 heats up and i replaced. Next, u2150 heat too and replaced! After that the components doesn't heat anymore! But don't have any image...
an help? thank you??
smiba
Voltage of PPVCC_S0_CPU?
ALL_SYS_PWRGD High? PM_PCH_SYS_PWROK High?
EDIT:
The component you posted is indeed U2150 on my board view as well
Since its connected to PM_PCH_PWROK, I would not be surprised PM_PCH_SYS_PWROK is low for you
I have to ask do you ever get boards that aren't fucked up by someone else? I wouldn't waste time on this one it looks fucked even in the picture.
Noguinfor
i am of the same opinion as you, but you usually charge 50€ more in my opinion it should 100€.. But i work for others and i have a boss!! i do not usually wast time in this boards but sometimes a different idea solve the problem.. i already realize this board this board will be difficult to solve.. You can close the post.. Thank you Duke
