820-2936 liquid spill causing questionmark folder
elcapitan
Hey Guys, I have a water damage mac book pro that came in completely dead with a fainted green light. I was able to make it turn on by removing the short on PP3V42_G3H. Now when the computer boots up it flashes a question mark non stop. I already tried a new HD cable but I'm still having the same problem. The area around J4501 and U4510 looks pretty clean; no signs of corrosion. I have attached a image of the areas that got affected by the water damage. As you can see, most of the damaged occurred near the firewire and T29 boost circuitry.
Any suggestions?
Thanks for the help!!
HDD spinning up? Is there a bootable OS on the HDD?
Boot from USB drive and install a known good HDD and see if it is recognized.
elcapitan
Thanks for your response Duke. When I boot from a usb drive and install on a known good HDD, I get the following error "OS X could not be installed on your computer-File system verify or repair failed. Quit the installer to restart your computer and try again". It's weird the disk gets listed during installation. It also appears on disk utility. I already tried a HDD with a bootable OS. I also hear the hd spinning. Any suggestions? Should i be focusing on certain lines? Thanks!
Set the date to at least something in 2016 and try to install again, can do that in terminal with "date" command. If the drive is listed in Disk utility all hardware is probably ok.
elcapitan
Thanks for your response. I tried setting the date to todays date and reinstalling the os but i still got the same error. At this point, im not sure if i should spend more time on this since the customer only paid me to fix the dead board. Shouls i let him figure this out Whats your opinion? I also noticed the t29 boost circuitry area gets extremely hot. Should i bother fixing this circuitry? Thanks!
elcapitan
What gets hot? Q9425 usually gets fucked and will cause battery drain.
to be exact, U9480 gets really hot. Should i bother fixing this circuitry? What do you think i should about the installation problem? Should i let the customer figure that on his own?
