Jay
Hi Folks,
Got a 820-2936 that runs slow yet passes all AHT and ASD (OS and EFI) tests.
Dirty inside but after a good cleaning no signs of corrosion. Same behavior with or without battery and other component isolation.
Figured this would be a sensor issue but no issues are found.
This was handed to me with reports of slow performance and occasional fan on max behavior (have not seen the fan on high myself).
Prior to cleaning the Mac froze when booting from a USB KG OS and restarted itself when I tried to launch an app, this behavior is gone after cleaning.
Also had the 3 RAM beeps once after assembly but reseating the RAM solved that. Battery is a compatible model A1322.
If not a sensor issue, what could cause the slowdown?
